What Kind of Stance With This Setup
Old Nov 14, 2013 | 04:56 PM
miseroth's Avatar
I am considering the following options on my 2007 Screw 4x4 (5.4L with 3.73 gears). Let me know how this set up might look (tires stick out too far?) or if I might have any rubbing issues:
35x12.50R20LT Toyo Open Country M/T tires wrapped around Metal Mulisha series 5038 General, 20x9 with 6 on 135 bolt pattern
2" or 2 1/2" level
Thanks!
Old Nov 14, 2013 | 08:04 PM
laj99150's Avatar
Backspacing and offset of wheels? that will really determine if there will be rubbage... or stick out too far..
Old Nov 14, 2013 | 09:10 PM
Galaxy's Avatar
X2. All the information you gave is useless in determining "stick-outage" without backspacing or offset (two different terms/measurement for the same thing BTW)
Old Nov 14, 2013 | 09:45 PM
miseroth's Avatar
My bad...
Offset = 0
Backspace = 5
Thanks!
Old Nov 14, 2013 | 11:24 PM
jdeacon's Avatar
my truck is leveled 2 inches, with 12.5 inch wide tires, but my wheels are 10 inches wide and have a -12 offset. so mine stick out 25mm more than those would, which is one inch
Old Nov 15, 2013 | 12:29 PM
wandell's Avatar
You will need more lift to fit a 35x12.50 on a 9 inch wide wheel. Or you can go with 33's like jdeacon.
Old Nov 15, 2013 | 02:21 PM
miseroth's Avatar
Thanks for the info wandell. I have 33's on the truck now (Bridgestone Dueler H/T Alenza) with stock wheels and no lift, so I was trying to get something a little larger without going with the all out 6" lift.
I may go back to my other idea of 2" Autospring level, stock wheels with 295/60R20 tires (maybe Trail Graps or Toyo M/Ts) and use a 1/4" spacer.
