Nitto Trail Grapplers for 2007 Screw
I am looking to get a 2" Autospring level for my 2007 Screw 4x4 and new tires - Nitto Trail Grapplers 295/60R20 to go on my stock 20" wheels.
I wanted to double check and make sure that I am not going to have any rubbing issues as well as get opinions on these tires - how long should they last, how is the road noise and any other comments.
Thanks!
Thanks!
The deep backspacing may cause some rubbing using the factory 20's...I ran some 305x55x20 AT's on my 20's that were real close on the inside but no rubbing. Any rubbing with the 295x60's may be due to the sidelug's on the Trailgrappler's. Ought to look great after installing them!
He does have spacers, but I think he had the tires without them for a while and only added the spacers for looks mostly. Maybe he had 1/2" before and then went to the current 2" ones
Here we go:
https://www.f150online.com/forums/wh...s-oem-20s.html
He had 1/4" wheel spacers, then moved on to the 2" ones recently.
Was thinking about the same 295/60r20 and found this, scroll down towards the bottom, pic with 2" level kit, that tire size on stock 2010 FX4 20" plasti dipped wheels.
http://www.f150forum.com/f38/nitto-t...136774/index8/
Here we go:
I love the look personally. Perfect tire size and the nice stock 20s look good as well
I just called Wheel Adapters and it appears as if the 1/4" spacer is just a "flat spacer" - I am not sure if that is good or bad or indifferent but it apparently would be custom made.
I assume that this is the spacer that was used...looks like a PM to lakemarykid is in order to confirm.
