Wheel offset
Old Sep 6, 2012 | 03:26 PM
Linki24's Avatar
Wheel offset
Looking at putting 33x12.50 toyo mts on my 06 f150 but here in pa our tires can not stick out the side. So with that I was wondering what offset to run so my tires will be flush.
Old Sep 6, 2012 | 05:21 PM
jerrybizzle's Avatar
+35 or so with nine inch wide wheels will keep them near factory specs.
Old Sep 6, 2012 | 05:28 PM
Linki24's Avatar
Cool sounds good thank you.
Old Sep 6, 2012 | 05:45 PM
With the wider tires they will stick out slightly more than stock just due to the width difference in tires. Here is mine with eight inch wide wheels with +25 offset which is similar to nine inch with +35. 315 tires are about 12.3 width. Fairly flush.
Old Sep 7, 2012 | 10:09 AM
Linki24's Avatar
That's probably the way i will run mine. Thanks for the pictures helped out a lot.
Old Sep 7, 2012 | 02:15 PM
You're welcome. Good luck.
Old Sep 7, 2012 | 06:51 PM
I didn't know of that little PA rule, i have the toyos in 33x12.5 with +18 offset, stick out about an inch and a quarter past the fender flares. Never been hassled for it.
Old Sep 7, 2012 | 08:19 PM
Linki24's Avatar
Yeah depends on the cops lol but in PA they can stick out up to 3" if you have flares, but I have a step side and can't seem to find decent looking flares. I liked the bushwhacker pocket style but they don't make them for the step side. At least that I can find.
Old Sep 7, 2012 | 08:39 PM
Linki24's Avatar
Seeing how you are from Mansfield as well at least I know I should be able to get away with a little extra
