22" Harley Davidson F150 Wheels, what psi?
Old 04-11-2012, 10:53 AM
rayofsi's Avatar
I am running 22" harley davidson f150 (2010) edition wheels on my ford expedition, does anyone know what the psi would be on the f150 for the 22", i don't tow or anything, just a daily driver, and i dont know if going with the recommended pressure for my 18" wheels is enough
Old 04-11-2012, 11:08 AM
kingfish51's Avatar
It has absolutely nothing to do with the wheels. What tires do you have on those wheels. Brand, model, size, and especially load rating at what pressure needed.
Old 04-11-2012, 11:15 AM
rayofsi's Avatar
i have the oem pirelli that they have
Pirelli Scorpion Zero Asimmetrico
http://www.tirerack.com/tires/tires....utoModClar=4x4
Old 04-11-2012, 11:26 AM
kingfish51's Avatar
That is an extra load P series tire. Max pressure of 50. 2469lbs at 50, which because it is on a truck is reduced to about 2200lbs at 50. I would run them at a minimum of 42, with 45-46 being the optimum.
Old 04-11-2012, 11:59 AM
rayofsi's Avatar
wow never knew how these ratings work
just to clarify, i have a ford 2011 expedition, it is a daily driver, i do not tow, the heaviest load my ford sees is me + 4 passengers. guessing my 35 psi right now is too under inflated.
Old 04-11-2012, 01:35 PM
kingfish51's Avatar
That 35 depend upon the tires. Standard load P series tires at 35 give you their full weight carrying ability (minus 10% for being on a truck), even though their max is 44. The extra pressure is to help with sidewall stability when carrying heavier loads.
For your Expy, what is the GVWR (max weight) and GAWR (max weight on each axle). That info should be on the door sticker. That will give you a better idea on what pressure is needed. You need to be able to support that weight.
Old 04-11-2012, 02:21 PM
rayofsi's Avatar
Thanks, i do realize that my previous 18" tires are SL, and my current 22" tires are XL, seems that SL is rated at 35 psi, while XL is rated at 41 psi
would it be safe to assume that what my 18" does at 35psi, my 22" tires require 41 psi to work the same? Very new to this and never even realized things like load ratings before.
Old 04-11-2012, 03:19 PM
kingfish51's Avatar
According to here, http://www.tirerack.com/tires/tirete....jsp?techid=55, that would be correct.
That means you could go a few lbs lower, about 37-38. That should give you up to 2000lbs per tire and better sidewall stability.
Sorry about the original numbers, I am used to regular P series which always has to be at least 35 on these trucks or LT tires where you really need to calculate it out and the max weight is at max pressure.
Quick Reply: 22" Harley Davidson F150 Wheels, what psi?
