wheel newbie....help pls
Old Mar 7, 2012 | 02:04 PM
BigKais89's Avatar
So I'm thinking of putting some custom wheels and nice tires on my truck. I have a 2007 stx Reg cab 2wd that I'm slowly blacking out so nice black wheels are a must. What do I need to know regarding size besides that I need 6 lugs and am looking for a 17" wheel. I'm looking to run 32s or 33s with my 2" leveling kit...wheel wise I was looking at 17s. What else should u know when picking out rims for my ride?
Old Mar 7, 2012 | 02:08 PM
BigKais89's Avatar
O and for tires I ve really become a fan of the nitto terra grapplers in a 265/70-17 or possibly a 285/70-17 if I'm feeling ambitious spending wise. From what I've heard the terra grapplers are awesome tires. I've also looked at Yokohama geolander ATS and falken high countries.
Old Mar 7, 2012 | 07:23 PM
Cash@TireRack.com's Avatar
Former Sponsor
Check out the new ATX force (this pic is bright PVD - imagine it in black... Tire Rack has it!) $213 each.
http://www.tirerack.com/wheels/Wheel...ish=Bright+PVD
Old Mar 7, 2012 | 09:26 PM
BigKais89's Avatar
Will I have any issues clearing a nitto terra grappler in 285/70-17?Its 32.8" or so
Old Mar 7, 2012 | 10:36 PM
jerrybizzle's Avatar
If you keep the backspacing and offset close to stock specs you won't have issues with the 285s even with 2wd. I ran the 285/70/17 terra grapplers on my 4wd and they were good tires, just a little small on mine so I switched to 315/70/17 falken wild peaks, which are also good tires. My wheels are eight inches wide with 5.43 inches bs and a positive 25 offset. Similar to stock. A nine inch wheel with around 6 inches bs and a positive offset will allow largest tire fitment. I have zero rub and didn't trim anything.
Old Mar 8, 2012 | 08:40 PM
MookTastic's Avatar
Also new to tires
I have a 2005 xlt super crew. I'm stock as of right now with 265/70 17. Was wondering if I can run 285/70 without doing a leveling kit. On a side note did you put the black bumpers on? If so where did you get them? Thanks
Old Mar 8, 2012 | 11:35 PM
If 4wd you can fit them without level. I had mine on pre level with no rub. If 2wd you will ned the level if you don't want rub. As for the bumpers, I had chrome bumpers which I sanded down and painted with rustoleum bedliner spray. I would recommend plastidip as it can be peeled off if you don't end up liking it instead of painting. Couple pics pre level and chrome bumpers.
Old Mar 12, 2012 | 08:10 AM
MookTastic's Avatar
Yeah right on I like that about your bumpers. So my brother in law told me that with a leveling kit I can go as big as 35's. If that's the case than I'm totally down for that. But I know back spacing is going to be a problem, which I still don't fully understand. So may end up saving up more money for some nice wheels.
Old Mar 12, 2012 | 06:07 PM
BigKais89's Avatar
can i run the 285/70-17 terra graps on my 7.5 oem rims. the rim range says 7.5-9.5 but the measurements for the tire are based on a 8.5 rim.
Old Mar 13, 2012 | 12:19 PM
wandell's Avatar
Yes.
Old Mar 13, 2012 | 12:49 PM
BigKais89's Avatar
Originally Posted by wandell
Yes.
thats the direct answer i was lookin for...thanks lol
Old Mar 15, 2012 | 09:59 PM
Langston7145's Avatar
I have 325/60/18 terra grapplers on my 07 4wd and they rub slightly when turned all the way. Those are 33"
Old Mar 16, 2012 | 09:45 AM
Myself and member cagerattler both have 315/70/17 which is close to 35 without any issue. My specs are above for eight inch wheels and he has nine inch wide wheels, with just over 6 inches bs and +35 offset. Neither of us trimmed or rub.
