Wheel Offset
Old Jan 26, 2012 | 07:50 PM
Cellside's Avatar
Wheel Offset
Hey guys,does anyone know the factory offset for 20in ford f150 wheels?I'm looking to get 20in boss wheels(330 or 316) and there offset is +20 or +40,I want to see if these are going to stick out or be flush like the factory 20s
Old Jan 26, 2012 | 07:53 PM
atr04screw's Avatar
I believe the stock 20s are either +35 or +42. I'm not positive what it is, but it is somewhere around there. The +40s would be almost identical to stock, and the +20s would stick out around 1" further than stock.
Old Jan 26, 2012 | 10:50 PM
Cellside's Avatar
Thanks bro,is there anywhere I can double check I tried Google but I can't find any solid info on the stock offset.
Old Jan 26, 2012 | 10:53 PM
fine_style150's Avatar
http://rimsntires.com/specs.jsp
this can let you play with tire size rim size, offset etc
Old Jan 27, 2012 | 01:35 AM
Cellside's Avatar
I played with it before but...I does no good for a comparison on offsets if I don't have the actual F150 20in offset number
Thanks though
anyone else?
Old Jan 27, 2012 | 11:21 AM
more then likely all OEM wheels are +42 or +44. which is roughly 6" backspace. it makes sense as i don't see why ford would change how much a wheel sticks out on a vast series of trucks with the same lug pattern/chassis
regardless, i used the model of +44 when rim shopping for mines, and it came out close to the real thing. what look are you going for? would you mind having the tire stick out a 1/4"? i like when the rims are flush to poking a bit, so if i were rim shopping i'd do the +20. do you have flares on your truck? that accounts for like 1/2" IIRC
Old Jan 27, 2012 | 12:15 PM
wandell's Avatar
The OEM 20's are 8.5 inches wide with 6.5 inches of backspacing.
Old Jan 27, 2012 | 09:17 PM
bingo!
