post pics of 33 inch tires
Old Apr 25, 2011 | 07:06 PM
Desert Dawg's Avatar
Originally Posted by jared123
yea these are some awesome trucks desert lol beast *** fords boy.. and yea ok so im going to get 33 inch tires and 18by9 rims.. then maybe a 2 or 3 inch lift kit? or what should i do? if i get a body lift do i have to get a suspension lift to? and new tortion bars?
Thanks! Assuming you keep your backspacing and offset within reason and use some keys to crank your torsion bars, the 33s on 18x9s should be fine. A 3-inch body lift would be a good solution if you don't mind seeing some frame and relocating the bumpers (check out Performance Accessories as their kits are pretty complete and very good quality - I used the PA body lift on a couple of Tahoes and it worked out great to fit some 33s with wider wheels). But either way, you don't need a suspension lift unless you want to go higher (4-6 inches) to mount some 35s or do what Wandell did with cranking the torsion bars with a body lift to fit the 35s.
Old Apr 25, 2011 | 10:58 PM
Msbowhunter's Avatar
Heres a question. It may be stupid but I'm just making sure. Will a 33x12.5x18 tire fit without rubbing on a 2.5 leveled 06? I know the 33 diamator is not a problem. But what about the 12.5" wide tire? It just doesn't seem like there's enought room behind my stock tires for an extra inch or so. My current tire size is 275/65/r18 and I'm on the stock rims. Can someone please help me.
Old Apr 25, 2011 | 11:54 PM
jerrybizzle's Avatar
I think that 295/70/18 is a better size with stock wheels and level. Some members are running stock king ranch 18s with that size and it looks great. They are roughly 34 inch. If u want 33s I would go with 285/65/18. Will the 12.5 inch rub on stock wheels I am not sure. What I do know is that although some on here run that wide of tire on stock wheels, most manufactures recommend minimum of 8.5 inch width and the stockers are usually 7.5 or 8. The 20s are wider.
Here's mdhawkins with 295/70/18.
[IMG][IMG][/QUOTE][/IMG][/IMG]
Old Apr 26, 2011 | 07:26 AM
Ok thanks man. That size is fine with me. I've been considering some tires like the trail grappler and they do come in that size
Old May 5, 2011 | 12:46 AM
SkiDood's Avatar
Originally Posted by Desert Dawg
okay...
33s with 2-inch leveling lift:
35s with 4-inch suspension lift:
dDawg, I have a couple questions for you regarding these two that I hope can benefit many here deciding on what to do for tire upgrade:
1) describe the change in ride quality between stock, level, and lift?
2) Difference in backspace between the two and your thought between the two wheels
3) either of these wheels clear coated? Easy to keep clean?
4) your impressions of the highway ride quality between stock tires, BFG ats, and BFG mt?
5) corrected mileage between stock setup, levelled, lifted?
6) your opinion if 33s might have fit without the level?
I know thats a lot of questions but the answers could be enormously valuable to many...
THanks!
Old May 5, 2011 | 09:25 AM
pylda's Avatar
okay...
I need tire and wheel specs for this set up. Thanks.
Old May 5, 2011 | 09:30 AM
THanks!
Answer to number 6 is yes they will with proper offset and bs. Here's mine pre level with 285/70/17. Pretty sure I could have fit 295/70/17 with very minimal rubbing. Wheel specs are 17x8 with +25 mm offset and 5.43 inches of bs. No rub at all. See profile for pics after level if interested. And for number 5 an aftermarket programmer will be able to correct that.
[IMG][/IMG]
Old May 5, 2011 | 12:48 PM
SkiDood's Avatar
I know the truck speed and odometer can be corrected I'm interested in an odometer corrected change to fuel mileage after the wheel/tire change (if its known). Too many people report losing Xmph and didn't correct their speed/odometer or at least take the tire size change into consideration when making the calculation.
Old May 5, 2011 | 12:51 PM
SkiDood's Avatar
From D-Dawg's link above:
33-inch BFG All Terrain KOs mounted on 18-inch Eagle Series 197 Wheels
I looked into these wheels and looks like they only come in 9" wheel with 4.5" backspace, so there you have it! Those are aftermarket flairs so I'm sure it has a nice wide stance with the backspace compared to stock. And to DDawg's credit, that is a great picture!
Old May 5, 2011 | 12:57 PM
That depends on what size u end up going with. Obviously the bigger the tire, the more negatively it will affect mileage. Larger diameter and heavier. Also have heard that mud terrains will drop it as well. I just averaged 15.2 on my last fill up with the 32.8 inch diameter of the tires versus the stock 31s. I got about the same with stock tires before mods. I added intake, exhaust and programmer which helped with mileage and I drive pretty mild. 3.55 gears. I would say u will lose 1 mpg or so if u go from stock to 33s.
Old May 5, 2011 | 12:58 PM
jlyoung08's Avatar
305 70 17 with a 2.5 level kit and dc1's
Old May 5, 2011 | 03:45 PM
Milt IV's Avatar
so are these tires the 305/65/18s ??? im looking on the BFG site and i see they offer 285/65/18, 305/65/18 and 325/65/18 in this model. i want these exact same tires you have on the 18s im gonna get for my 4x4 desert dawg.
Old May 5, 2011 | 05:45 PM
f150fella08's Avatar
im running 305-70-17 torsion bars turned up a bit
Old May 5, 2011 | 09:44 PM
Galaxy's Avatar
4" lift and 33's...IMHO, a perfect fit for this body style!
Old May 5, 2011 | 10:41 PM
^^ nice, but i think you should go 35's
