Rear brake hose
Rear brake hose
This is my first thread so be gentle, please. I am having an issue with a rear passenger break sticking on an 04 Lariat Screw. I have narrowed it down to a deteroriated hose not allowing the fluid out of the caliper and thus holding the pads to the rotor. I picked up a hose from Napa today but I could not get the old hose loose frome the metal line. After looking at the connection longer I am not so sure that the hose will disconnect from the metal line. I also have a 08 FX4 and I could clearly see where the metal line will unscrew form the hose but it is not so clear on the 04 Lariat. So my question is does anyone know if the metal line will unscrew from the hose or will I have to replace the line from the t on the axle to the hose on the caliper.
