35's w/ 6" lift - rubbing issues?
Old Mar 25, 2011 | 05:10 PM
rrozell's Avatar
Have 6" skyajcker kit and 35" Nitto trail graps at home. Anyone have issues with 35's rubbing with a 6" lift? Would like to know if I am going to be doing some cutting before I have kit put on.
Old Mar 25, 2011 | 05:47 PM
1BADRAPTOR's Avatar
I have a 6" fabtech on my 08 f150 and 35 12.50R18 trail grapplers and they did rub even after the alighnment. So I had to cut the front valance it was at full lock on both sides and my crew cab with a 6.5ft bed turns like a school bus so it had to be done lol
Old Mar 25, 2011 | 05:59 PM
rrozell's Avatar
It didnt rub on the inner fenderwell?
Old Mar 25, 2011 | 07:04 PM
TheDesertRat's Avatar
I have a 6" Fabtech lift with 35" Trail Grapplers and mine rub in the rear inner fender well. There are some here who will tell you their's do not ever rub but I find it hard to believe. Mine will rub just coming into my slanted driveway at an angle. They don't hit hard but there is black transfer on my white plastic. I am not looking forward to seeing what happens when I wheel it harder which I haven't done yet since I just got it a while ago. You do want to check the backspacing on your rims though as that can make a difference.
Old Mar 25, 2011 | 07:09 PM
rrozell's Avatar
My rims are 4.5"bs. Thats the largest you can use with skyjacker kits bc of the steering knuckle setup they use.
Old Mar 25, 2011 | 07:54 PM
1BADRAPTOR's Avatar
I dont think mine rub the inner fender well just the valance is all I could see but when I turn and hit a dip it dose rub somewhere not shure tho.
Old Mar 25, 2011 | 09:57 PM
wandell's Avatar
It all depends on the width and backspacing of the wheels you use. You may have rubbing with a 10 inch wide wheel with 4.5 inches of BS and none at all with a 9 inch wide wheel and 5 inches of BS.
Old Mar 25, 2011 | 10:03 PM
camopaint0707's Avatar
35's and a 6 inch lift? no way
Old Mar 27, 2011 | 07:08 PM
rrozell's Avatar
So are you saying they wont rub or they wont fit?
Old Mar 28, 2011 | 10:32 AM
Griff D's Avatar
They will fit, you may have some issues with your front valnce but i ran 35's on my 06 with a 3" body lift and i run 35's on my 10' now with a 6" lift and i rub some on the front valance not on the inner fender wall.
Old Mar 28, 2011 | 11:10 AM
rrozell's Avatar
At was at homedepot this weekend and parked next to a f150 with a 6" kit. decided to look at the front valance and now I see what everyone is talking about. he trimmed the corner of the plastic. What is everyone using to cut the valance with?
Old Mar 28, 2011 | 11:24 AM
Griff D's Avatar
I used a saw zaw but a cutting disc for a grinder would work fine
Old Mar 28, 2011 | 12:59 PM
rrozell's Avatar
Did it leave ruff edges? was thinking about use a skill/jig saw with plastic cutting blade on it. (its what I have)
Old Mar 28, 2011 | 01:11 PM
fx4 for life 79's Avatar
might rub on the valance but thats a easy trim
Old Mar 28, 2011 | 05:13 PM
Griff D's Avatar
no rough edges its pretty smooth if i still had the truck i would take a pic but i might be cutting the valance on my 10' if i do i'll take some pics
