F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Wheels, Tires & Brakes (https://www.f150online.com/forums/wheels-tires-brakes-29/)
-   -   35's w/ 6" lift - rubbing issues? (https://www.f150online.com/forums/wheels-tires-brakes/445040-35s-w-6-lift-rubbing-issues.html)
rrozell Mar 25, 2011 05:10 PM
Have 6" skyajcker kit and 35" Nitto trail graps at home. Anyone have issues with 35's rubbing with a 6" lift? Would like to know if I am going to be doing some cutting before I have kit put on.
1BADRAPTOR Mar 25, 2011 05:47 PM
I have a 6" fabtech on my 08 f150 and 35 12.50R18 trail grapplers and they did rub even after the alighnment. So I had to cut the front valance it was at full lock on both sides and my crew cab with a 6.5ft bed turns like a school bus so it had to be done lol
rrozell Mar 25, 2011 05:59 PM
It didnt rub on the inner fenderwell?
TheDesertRat Mar 25, 2011 07:04 PM
I have a 6" Fabtech lift with 35" Trail Grapplers and mine rub in the rear inner fender well. There are some here who will tell you their's do not ever rub but I find it hard to believe. Mine will rub just coming into my slanted driveway at an angle. They don't hit hard but there is black transfer on my white plastic. I am not looking forward to seeing what happens when I wheel it harder which I haven't done yet since I just got it a while ago. You do want to check the backspacing on your rims though as that can make a difference.
rrozell Mar 25, 2011 07:09 PM
My rims are 4.5"bs. Thats the largest you can use with skyjacker kits bc of the steering knuckle setup they use.
1BADRAPTOR Mar 25, 2011 07:54 PM
I dont think mine rub the inner fender well just the valance is all I could see but when I turn and hit a dip it dose rub somewhere not shure tho.
wandell Mar 25, 2011 09:57 PM
It all depends on the width and backspacing of the wheels you use. You may have rubbing with a 10 inch wide wheel with 4.5 inches of BS and none at all with a 9 inch wide wheel and 5 inches of BS.
camopaint0707 Mar 25, 2011 10:03 PM
35's and a 6 inch lift? no way
rrozell Mar 27, 2011 07:08 PM
So are you saying they wont rub or they wont fit?
Griff D Mar 28, 2011 10:32 AM
They will fit, you may have some issues with your front valnce but i ran 35's on my 06 with a 3" body lift and i run 35's on my 10' now with a 6" lift and i rub some on the front valance not on the inner fender wall.
rrozell Mar 28, 2011 11:10 AM
At was at homedepot this weekend and parked next to a f150 with a 6" kit. decided to look at the front valance and now I see what everyone is talking about. he trimmed the corner of the plastic. What is everyone using to cut the valance with?
Griff D Mar 28, 2011 11:24 AM
I used a saw zaw but a cutting disc for a grinder would work fine
rrozell Mar 28, 2011 12:59 PM
Did it leave ruff edges? was thinking about use a skill/jig saw with plastic cutting blade on it. (its what I have)
fx4 for life 79 Mar 28, 2011 01:11 PM
might rub on the valance but thats a easy trim
Griff D Mar 28, 2011 05:13 PM
no rough edges its pretty smooth if i still had the truck i would take a pic but i might be cutting the valance on my 10' if i do i'll take some pics
