AR Crawl or Ultra Maverick - Opinions Please
My better half has browsed through a selection and has chosen either the Ultra Maverick or AR Crawl wheels as "acceptable" for our soon-to-be-delivered 2011 Lariat Screw in White Platinum Metallic Tri-coat paint.
I am set on the Goodyear Duratracs.
The two setups would be:
1) DT 275/70R18 on 18x8.5 AR Crawl (BS=5.34", Off=+15mm)
2) DT 295/65R18 on 18x9 Ultra Maverick (BS=6", Off=+25mm)
Will the 295s extend beyond the fender? If so, they are probably out.
In your opinion, which would look better on our Lariat?
Ultra Maverick
AR Crawl
Ultra Maverick
AR Crawl
Ultra Maverick
AR Crawl
Ultra Maverick
AR Crawl
Thanks for the feedback. Keep them opinions coming.
If I go with the Mavericks and the 295/65R18 tires, will there be rubbing, or will they stick out beyond the fender?
Mavs, Backspace=6", Offset=+25mm
295/65R18, Width=11.6", Diameter=33"
I've been told (by the Ford parts guy at my dealer) that the stock 18" wheel is 7.5" in diameter, but I don't know the backspace or offset. The stock tire is 275/65R18 (width=10.8", diameter=32").
An 8.5 inch wide wheel with 5.34 inches of BS will stick out about 1 1/4 inches farther than your stock wheels. A 9 inch wheel with 6 inches of BS will stick out an inch farther than the OEM wheels.
You stock wheels have 5.5 inches of BS.
I wish! Better half has her limits. Perhaps I should see how far those limits can be stretched?
For example, the stock tires are 275mm wide (10.8") and the Duratracs I will go with are 295mm wide (11.6").
If I go with the Mavericks, we've already determined they will stick out 1" based on the wheel differences.
Would I also need to account for tire width differences? So would I need to add an additional 0.4" ((11.6-10.8)/2) to reach my actual "stick out" number?
I have the chrome Mavericks on my 04 SCREW in the 20x9 with a +30 offset with 305 tires and in the front they are almost perfectly inline with the top of the fender flares. I don't know how they would look in the 18's, hopefully better than the 20's. I'm not completely happy with the looks of the 20's for the Mavericks. They are just a little to open for my taste and I have thought of looking for a different wheel. Have you seen a picture of them in the 18 just to make sure you like the looks? Just curios, I wouldn't have bought mine if I saw a 20 inch picture of them.
Tim
Tim
Tim
Tim
At any rate, I pulled the plug and went with the 18x9 Mavericks wrapped in 275/70R18 Duratracs from Discount Tire. There were a few of factors:
1) Ordering online wasn't going to save me a huge amount vs. Discount Tire.
2) Discount Tire had 2 $50 rebates (1 for 4 wheels, 1 for 4 tires). It ended today, so I had to figure things out fast.
3) I asked the manager what if I didn't like the wheels (they weren't on site)? He said that I could just return them. No restocking fee? Only if they are mounted. This was huge.
4) I wanted to support a local business.
BTW, the guys at my Discount Tire were super cool to work with.
So, I've purchased new wheels and sneakers and I don't even have my d@nm truck, yet.
Now... what else do I need, I mean want?
So, the better half likes the look of the wheels/tires... then goes on to say, "the truck needs to be higher." Me: What?? Who are you?? I don't even know you anymore.
Then again, we swapped from a 99 F-250 SD Crew.
Maybe that lift isn't out of the question. I need to start working this. Make her think it's her idea. I hope she doesn't lurk in this forum.
