38x13.5 or 38x15.5??
Old Mar 10, 2011 | 08:36 PM
Tarpon-Screw's Avatar
need help deciding which tire size to run.....01 supercrew 9"s of lift on 20x12 -44 offset wheels with 4.75"s of backspacing.... more or less will the 15.5's fit with out rubbing? Its a DD also. and yes its getting re-geared
Old Mar 10, 2011 | 09:52 PM
wandell's Avatar
I'm pretty sure 38x15.50's won't fit.
Old Mar 10, 2011 | 09:54 PM
1997bigredf150's Avatar
I had a toyo open country M/T 38x15.5 on a 18x10 -25 with 4.50 backspacing and had rubbing on the frame but they look much more aggresive then a thinner tire.
Old Mar 10, 2011 | 09:59 PM
wandell's Avatar
Just as a point of reference, several members have fit 38x15.50's on 97-01 4x4's by using a 3 inch body lift, cranking the torsion bars all the way up and using a 10 inch wide wheel with 4.5 inches of bs, but they still had some rubbing. I think the 12 inch wide wheel is gonna cause you problems.
Old Mar 10, 2011 | 10:24 PM
thats basically my truck and thats exactly what i said....here are your options
1. Let it rub (harder to get into parking spots and maybe not that safe)
2. Use spacer (they add a new vulnerability and I would never)
3. Go with the 13.5
Its your decision!
So out of curiosity what gears?
Old Mar 10, 2011 | 10:32 PM
Yukon 4.88s. I have a set Of 18x10s -27 offset not sure on the bs. Maybe those with the 38x13.5's
Old Mar 11, 2011 | 06:10 AM
The 18s are -24 offset 4.5 backspace
Old Mar 11, 2011 | 11:10 AM
fx4 for life 79's Avatar
id stick with a 13.5 but you still might rub some
