Damage from pot hole
Old 02-21-2011, 01:24 PM
Kishan's Avatar
I have an 08 F150 FX4, and hit a pretty bad pot hole with the rain we had over the weekend.
Threw the alignment off, and when steering wheel is in the left position I hear a knock from the front end. Doesn't make a sound when turning right. I'm thinking a bad cv joint? Any other suggestions what it could be and of any place to buy parts from?
Old 02-21-2011, 01:34 PM
RandomHero34's Avatar
parts can be bought from rock auto. Its a great place with fast shipping. Im not sure what the problem would be though.
Old 02-21-2011, 02:14 PM
kingfish51's Avatar
If in 2wd, the CV joints are not turning, so they should not be making noise. My guess is something else.
Old 02-21-2011, 03:00 PM
Kishan's Avatar
If it helps, I hear the noise in 2wd when moving slowly from idle to 10+ mph with steering wheel at or near full lock left.
Old 02-21-2011, 03:32 PM
05RedFX4's Avatar
Could just be a tie rod end, 22 bucks at your local vato-zone. Mine went out with only 31K on the clock.
Old 02-21-2011, 05:05 PM
Kishan's Avatar
Update on the sound driving in a circle at full lock left, noise isn't consistent. In making 3-4 circles I heard a thud/knock type sound maybe 3 times. When coming out of the circle and wheel is just about straight I hear the sound one more time.
Here's a pic from the passenger side, side which I hit the pothole. Noticed there's a bunch of grease sitting there.
Driver side for reference:
Old 02-21-2011, 05:43 PM
05RedFX4's Avatar
From the pics I'd say your passenger side outer cv joint is toast. You wore or tore a hole in the boot and over time lost most or all of the grease which caused a premature failure of the joint. Oh and the pothole did not do that, you've been slinging grease for a while. The pothole may have been the last straw that broke the camels back but it didn't cause the failure.
Old 02-21-2011, 05:54 PM
Kishan's Avatar
Thanks for your help. You think I could get away with having Ford warranty this? Keep in mind I'm on 33's with aftermarket wheels + 2.5" Level kit.
Old 02-21-2011, 06:01 PM
05RedFX4's Avatar
depends on your mileage and how friendly your local dealer is.
Old 02-21-2011, 06:15 PM
Kishan's Avatar
16,000 miles warranty is up Dec this year. Been going to the same dealership since I was 17 with my Mustang. I'll cross my fingers.
Then again same dealership reinstalled my catback backwards on the Mustang after doing transmission work, I pointed it out to them and they told me I was shiit out of luck. They made some BS excuse end sent me off my way without fixing it. That was a while ago though.
Old 02-21-2011, 06:20 PM
05RedFX4's Avatar
If you still have warr it doesn't hurt to try. Worst they can say is no.
Quick Reply: Damage from pot hole
