285/75/18 + 2008 18" Factory wheels question
Old 01-21-2011, 09:14 PM
BLKFx4Screw08's Avatar
Hello everyone, I just received my Toyo M/T 285/75/18 and called to setup an appointment to have them installed and was told that it was unsafe to run an 11.5 inch wide on a 7.5 inch wide wheel. The salesman said I need at least a 8.5 inch wheel for it be safe. Is this true or was he just trying to sell me new wheels? I have a 2008 FX4 with the 18x7.5 wheels. Please let me know what you guys think.
Old 01-21-2011, 09:34 PM
brentb06's Avatar
tires
they will be fine on the stock rims. I had 325 60 18 toyo at's on the stock rims and there 13 wide.
Old 01-22-2011, 03:43 AM
CaliKid's Avatar
For 12.5 inch wide tire the smallest rim you can run is 8.5inches, so by that im assuming that a 11.5 inch wide tire would work fine.
Old 01-22-2011, 12:03 PM
ford0218's Avatar
I just got 285's put on mine last week and had no problem. Tell them to get over it and put them on or take it somewhere else
Old 01-22-2011, 12:11 PM
wandell's Avatar
I throw the BS flag. Thousands and thousands of F-150 owners here and at FTW have been running 285mm (11.50 inch) to 315mm (12.50 inch) wide tire on the OEM 7.5 inch wide wheels since 1997 with no problems. Most manufacturers recommend at least an 8 inch wide wheel for 12.50 inch wide tires, but I believe most manufacturers approve a 7.5 inch wide wheel for 285mm wide tires.
Old 01-22-2011, 12:14 PM
westtnfx4's Avatar
Yeah find another shop thats not stupid. They will be fine
Old 01-22-2011, 12:24 PM
philly164's Avatar
that's BS,,i'm running 325/65/18 on stock rims,,no problems,,,,,,,,,
Old 01-22-2011, 06:57 PM
Thanks guys, I found another shop that didn't even mention that it might be an issue. They are going on monday and I'll try to post up some installed pics.
Old 01-22-2011, 08:06 PM
I agree, those tires will fit easily on the stock wheel's. The narrower width should clear the upper control arm too.
Quick Reply: 285/75/18 + 2008 18" Factory wheels question
