Will 2010 20's fit my 2007
I googled and read a lot about 17's hitting calipers on the 2010's. This leads me to think I should be okay. I have a chance to pick up some 2010 FX4 20's with tires and TPMS for $600.00
What do you think? Will the rims fit? What about the TPMS will they work with the 2007 system?
Cos
Cos
- why new mounting bands? I plan on buying them tires and all for now. They are already mounted (maybe I should have mentioned that), I just will need it to be re-programmed.
The sensor system on the 2010 truck is a valve type sensor and the sensor on the 2007 is a strap type sensor. Both are a 315mhz sensors. But the sensors on the 2010 truck can be learned by the truck where as the sensors on the 2007 requires a trip to the dealer to have them programmed. I would double check with the dealer on this one and make sure they will work.
Just pick up one of these tools from the Dealer or Ebay:http://cgi.ebay.com/ebaymotors/FORD-...motiveQ5fTools and re-set your own anytime. Works like a charm on my 07 with different sensors
Question for you guys. What max width tire could I run on these rims? I would like to get a 305/315 tire. I am not sure if it will fit with my stock rim offset.
I currently have a 3" spacer on the front fyi. Right now I have a 285 and it looks like a tractor trailer.
