Trail Grappler pressure
Trucks at the shop having 295/70/18 Trail grapplers installed. I asked them to put 40 psi in, (max of 80 marked on tire) they said that was wrong, that they would only put in what the sticker on the door called for, 32 to 35. I explained that these were higher load rated tires than the P275/65/18 BFGs it came with they said it didn't matter, the sticker was still correct. So what psi should I run?
Wow. Knew I liked these tires from the pics on some of your trucks, but the pics don't do them justice. Amazing how much better they look in person, especially when I'm used to the stock tires. Can just barely hear them at highway speeds. Definitely notice the extra weight going uphill, but well worth it.
I started out at 50 which is what I used to run in my Terra Graps. Well with this Trail Graps the ride seemed way to stiff and bouncy with 50psi. I went down to 40. With these 10 ply thick SOBs, you can lower the psi and the tire doesnt sag much at all. It will certainly soften your ride too. I have been happy at 40 for about 14,000 miles now.
