Whats the difference?
i parked next to a truck yesterday that had 295/70/17's nitto terra grapplers on it and i have 305/65/17 pro comp extreme all terrains and these other tires seemed bigger, are they pretty much the same width just and inch or more taller cause it sure seemed that way? thanks in advance for any info!!
Only about a half inch difference.
Compare the sizes yourself.
http://www.discounttire.com/dtcs/infoTireMath.dos
Another thing to keep in mind is comparing size to size across manufacturers is not comparing apples to apples. a 305/70 from GY is not the same as a 305/70 from BFG. There will be variances, so you need to consult that manufacturers specs to see what the dimensions are. How and where on the tire a manufacturer can make his measurements can vary and that's why some look and will actually be bigger than others. Keep in mind also, when you're talking about wheels and tires, as little as 5-10mm can make a huge difference that can be very noticeable to the naked eye. Even if the dimensions list out the same, differences in shapes and profiles will mess with your eyes also.
I had 215/45 17's Dunlops on my Lexus and went to a 215/45 17 Michelin and the difference was friggin night and day! And these two tires had the exact same specs, but you'd never ever guess it.
Maxxis makes a Buckshot and a Bighorn in that size, good tires and less expensive then the other's too.
