Chrome 20 questions
Chrome 20 questions
Hello everybody, I am currently thinking about buying some chrome 20 in. rims with some 35 in. tires. Here are some of the models I am choosing from. They mostly have an offset of +30mm. DOes that mean they will stick out or what. I want them to look wide but barely stick out. I want some all-terrain tires or something aggressive but kinda cheap. any recommendations are appreciated. Thanks
MP207 20x8.5 6-135/139.7 +30mm
Ion 198 20x8.5 6-135 +30mm
Detroit 885 20X9 6-135 +30mm
DIP D04 20x8.5 6-135 +25mm
You will be able to fit 35's on your factory's, but it depends what the bs is on the aftermarket. If you get a +30 offset I believe they will fit, but will stick in. When you have a lifted truck you don't want the wheels sticking that far in. It won't handle as good in turns. I believe it would look better with 20's and 33's that way you can get around a -12 offset wheel that will look really good.
Here's a picture of my truck with factory wheels. See how goofy it looks being so narrow?
ya i see that, but i like the way my 18s just barely stick out of the flares. just enough to make the mud on the outside of them.
My truck isn't lifted as high and I dont plan to. I just want filled fenders and aggressive tires to get me out of mud if I'm in it. As long as they don't rub.
Have you ever seen the truck that has the roush rims and big tires? Do you like the way that looks or not?
Now that I think about it a guy around here use to have a truck identical to mine with 2.5" leveling kit, 20" Eagle wheels and 33" Toyo MT's and it looked pretty good. I'm not sure how much room he had if 35's would have fit.
There was a guy at the gym that had the roush front and bear bumpers with 20's and 33's. By the looks of it I don't think 35's will fit.
