97 Lug Nuts
Dealer. The 97's have 12mm studs and I believe they went to 14mm in 98 up. The wheels from the later models still work on yours even though the holes are larger for the 14mm because the wheels are hub centric. In other words the wheel is supported by the tight fit at the hub radius not the studs.
97-Nov. 29, 1999 = 12mm x 1.75
Nov. 30, 1999- 2003 = 14mm x 2.0
Check ebay.
http://cgi.ebay.com/ebaymotors/Ford-...Q5fAccessories
Check ebay.
