tire pressure question
Old Aug 1, 2010 | 04:13 PM
bellman's Avatar
I'm running bfg at 285/65/18's load range d (max psi 65) on stock fx4 wheels. What is the best psi to run for tread life?
Old Aug 1, 2010 | 06:26 PM
kingfish51's Avatar
I would run them at 45. Do not go lower than 40 if you try other pressures.
Old Aug 1, 2010 | 10:18 PM
wandell's Avatar
Yeah, I'd run 40 to 45 psi for daily driving.
Old Aug 2, 2010 | 09:11 PM
bellman's Avatar
Thanks for the info. I've been running them at 40, I bumped them up to 45 to see how they do. I've noticed my front tires are wearing on the outside edges. I just ordered a leveling kit yesterday so I will need to have it aligned after it's installed anyway.
Old Aug 2, 2010 | 09:52 PM
canadian_screw's Avatar
Get it aligned and rotate the tires.
Old Aug 2, 2010 | 10:37 PM
wandell's Avatar
I agree.
Old Aug 5, 2010 | 12:57 PM
07newscrew's Avatar
Correct BFG T/A Pressure
Question...I have the stock BFG Rugged Trail T/A 275/65-18 on my '07 King Ranch and the placard on the door says to infalte the tires to 35 psig. The label on the tire sidewall says that maximum inflation pressure is 35 psig.
I saw that bellman said his BFG T/A in the same size says maximum tire pressure is 65 psig.
Am I the only one with low pressure BFG's ?
Old Aug 5, 2010 | 01:41 PM
kingfish51's Avatar
His are a different size and load range, and possibly even a different tire, as he did not say which model. Yours are the OE tires that came from Ford. Other OE brands in the same size, like the Goodyears are a LR C tire and would have a different placard.
Yours are a P series tire (passenger car), a load range B.
Old Aug 5, 2010 | 01:52 PM
07newscrew's Avatar
Thanks kingfish51. I guess I didn't realize that my OE tires were classified as passenger tires even though my KR has the 7200# GVW and towing packages. That's probably why the truck rides and handles so nicely.
I do want to upgrade to a larger size 18" on the stock rim. Any suggestions? My truck isn't lifted but I will probably put the Bilstein 5100's on it to level it. I was thinking of going to an LT285/65-18 BFG T/A. Heard some good things about it on these forums.
Old Aug 5, 2010 | 01:55 PM
kingfish51's Avatar
The TAs are good tires, I run them for winter tires. The tires you mention are a LR E tire, with a max pressure of 80. A bit of overkill on an F150, but will still work well. You will notice the ride will be a bit harsher, and you will have to run them at about 50 psi rather than 35.
Old Aug 5, 2010 | 02:02 PM
07newscrew's Avatar
I'll take those things into consideration when I go to buy tires. Thanks for the feedback.
Old Aug 5, 2010 | 03:31 PM
zxrider11's Avatar
The BFG AT TA also comes in a 275/70-18 size.
They give a little more sidewall, and measured 33.2" in diameter. And they are considerably cheaper that the 285/65-18'.
Old Aug 5, 2010 | 03:57 PM
nu-supercrew's Avatar
I have the BFG AT/TKO 285's and have been running 40 psi for the last 20k. Getting ready for a small trip this weekend and checked tire pressure. All good. On a whim I upped the pressure to 50psi. Immediately noticed a much firmer ride. I think I'll do 50psi up and 45 on the way back... see what's what.
Old Aug 5, 2010 | 06:28 PM
kingfish51's Avatar
At 40, you are at half or less of the load carrying ability of the tire. The GAWR of the F150 is about 4k per axle. At 40 psi, a LR E 80 psi tire doesn't even come close to be able to carry that load.
If your vehicle had come with a TPMS setup and those tires, it would have been set to show low pressure at 46psi.
Old Aug 6, 2010 | 02:46 PM
ok
Just got off phone with BFG customer service. They calculated that for regular driving, optimum pressure for those tires on my '05 supercrew to be 41-43 psi.
(Tires ar LT 285 D load range. max pressure 65psi)
