Help with tire size
Help with tire size
I'm sure this has been asked a million and one times, What size tires can I run with a 2.5" leveling kit on a 2004 4X4? Right now I'm running 275/55/20. I was thinking 285/65/20 but all I can find those in are goodyear. I'm kind of wanting to go with Nitto or Toyo.
You are right, if you use the OEM wheels or one close to the same specs.
Also, you would have probably received more responses if you reworded the question. You basically said you didn't want to bother to take the time to search but wanted someone else to take their time to answer your question instead.
[IMG][/IMG]
