Stock 20" rims and tires question
Old May 3, 2010 | 09:50 PM
BigTFX4's Avatar
I have a set of the 275/55/20 Pirelli Scorpion tires on my truck right now, which after only 19,000 miles are just about worn out. I would like to go with a taller and wider tire, but dont know what size i can get away with. The truck is a stock 08 FX4. I dont have the leveling kit on it yet, but have been thinking about getting one put on. So that being said what can i get away with at the stock height, and at the leveled height?
Also i would like to go with a more aggressive tire. The truck is not my daily driver as you can see with it being 2.5 years old with only 19k on it, but i dont want to put a set of mud tires that are going to wear out rapidly by driving on the road.
Any help would be great.
Old May 4, 2010 | 11:47 AM
BigTFX4's Avatar
Anyone???
Old May 4, 2010 | 11:48 AM
ab46501's Avatar
I have 305/50/20 on stock wheels and they fit before and after my level kit was installed. The only issue I have is they rub the sway bar slightly in tight parking lots at full lock of the steering. I believe you can fit a 275/60/20 without a level as well on stock wheels.
Old May 4, 2010 | 12:08 PM
wandell's Avatar
I'd suggest some 305/55-20's (33x12.50).
Old May 4, 2010 | 01:35 PM
BigTFX4's Avatar
Thanks for the help with the size. Any suggestions on a good aggresive AT tire?
Old May 4, 2010 | 02:42 PM
colonelburke's Avatar
You may want to look a little further into your suspension as I have those same tires and have almost 40,000 miles on them with a little room left to go. I have heard the Toyo MTs last a pretty good time.
Old May 4, 2010 | 02:56 PM
ab46501's Avatar
I have the cooper zeon ltz and love them. Fully expect to get 50,000 out of them. I have close to 20,000 now with no real signs of wear. When I do go to replace them I will either get another set of coopers or go with the Mickey Thompson ATZ. Nitto, Toyo and BFG are all popular on here as well.
Old May 4, 2010 | 05:02 PM
wisconsinFX4's Avatar
you can fit 285/55/R20 (32.3" tall) or 275/60/R20 (33" tall) on your stock rims without a level...
Old May 4, 2010 | 05:19 PM
MTP-FX4's Avatar
get a 2.5" level and put some 35 inch all terrains on it
Old May 4, 2010 | 09:45 PM
dirk upson's Avatar
275-60-20 will fit on the stock wheels without a leveling kit. i have that size on my 08' 4x4.
Old May 4, 2010 | 10:02 PM
wandell's Avatar
I'd also suggest the BFG AT KO, Nitto Terra Grappler, Toyo AT, Pro Comp Xtreme AT, Mickey Thompson ATZ and **** Cepek FC II.
Old May 5, 2010 | 12:52 PM
gouldje's Avatar
I will be doing the same, I was thinking 285/65/20 BFG AT K0's
look at that option
Old May 5, 2010 | 05:37 PM
tripp dude's Avatar
I have the stock 20's and 33 nitto terra grapplers(along with many others) i love this setup, only rubbing i get is when it is in full lock, but a little trimming can fix that.
