What do you guys recommend?
I'd Figure id leave it to the pros. I have an 03 F150 supercab sidestep with 17 in rims. Im looking to get some new rims ( either 16 in or 17) and new tires ( 33's or 35s) thought Id ask everyone here. here are a few ideas what im looking for .
Moto Metal MO951 Black
Moto Metal MO957
Moto Metal MO958
Moto Metal MO959
ProComp Series 8023
Series 7105
Series 9001
Moto Metal MO957
Moto Metal MO958
Moto Metal MO959
ProComp Series 8023
Series 7105
Series 9001
yes i looked up the 9001 series they are a 17x9 5x135 they cost about $ 201 each. i think that would look good on my truck thats why i put that last and i looked up those nitto trail grapplers ($ 255 esch) and with that combination i think it would look sweet. thats exactly wat i was looking for thanks
i have made my desicion. Granite GA9 Rims 16x10 ($133)
Offset: -32mm
Backspacing: 4.21"
Bolt Pattern: 5-135
Rec. Tire Size: 315/70-16
Weight: 25.5lbs.
and Wrangler MT/R with Kevlar
$267.00 (ea.) 315/75R16 121Q Load Index 121 = 3267lbs (1485kg) per tire
Speed Rating “Q” = 99mph (160kph)
hows that for a truck to that off roading?
Offset: -32mm
Backspacing: 4.21"
Bolt Pattern: 5-135
Weight: 25.5lbs.
I had mine done on my old truck but I just had a shop do them for $10 since it needed an alignment afterwards anyways. I think from what I have heard, you just crank them until it looks level. It isn't always the same amount of turns on each side, but usually it will not be all the way. Just as a FYI as well you will probly have to trim a small portion of the plastic valence on the front bumper with those 16x10's and 35's
