2008 FX4 Wheel and Tire help
I have spent 3 days reading every google search possible including 1 hour of questions to Wandell. The problem is I am still not real clear.
Will a 17 inch will fit on my truck? I have 18s and have heard they wont work with 17s. The brake has a good 1.5 distance between the OEM wheel now.
What is the tallest tire I can run with my current 2.5 leveling kit? I have read anywhere from 33 to 35s.
I am going to order a wheel that is 17x9 with 35s if this is possible?
If not would a 285/75/17 Terra work? It is showing 33.86 tall and 11.30 wide.
Thanks for ANY input.
Thats a nice setup. Do you think you could have went with 35s? I am thinking the new wheel is 17x9 +15 offset with 5.5 backspacing. Is this good enough for a 35? What is your backspacing?
Wandell the wheel has a +30 offset. Would you be concerned about the fender rub or the inside of the tire? I dont mind a little trimming if that would mean I could use the 17x9. I really like this wheel but....
Thanks. Just got quoted for the same wheel in 18x9 with 5.75 bs and +19 offset with 295x70x18 trail grappler. That is a 34.5 inch high by 11.5 wide. I hope it turns out like Paw paws or AZFX4s trucks.
