TPMS light on
Old Feb 9, 2010 | 06:34 PM
wreedKR's Avatar
TPMS light on
I had my stock wheels and tires put back on today. They switched the TPMS sensors back to the old wheels yet the light is still on after 60 miles.
What should I do?
Old Feb 9, 2010 | 06:36 PM
GreenBuck50's Avatar
Do you have the proper tire pressure in your tires?
Old Feb 9, 2010 | 06:39 PM
wreedKR's Avatar
Yes it said sensor fault after about 30 miles.
Old Feb 9, 2010 | 06:42 PM
I would check with the shop that installed them then.
Old Feb 9, 2010 | 06:43 PM
wreedKR's Avatar
They said to bring it back and they will reset. I have the little remote can I just reset myself?
Old Feb 9, 2010 | 06:51 PM
I do not know, you are beyond my experience at that point.
Old Feb 9, 2010 | 07:41 PM
kingfish51's Avatar
Yes you can. The instructions should be in the owners manual. Does your truck have different pressure settings between front and rear? If so, that is why the light is on. Unless you got the tires in exactly the same between front and rear, it would think at least 1 tire is low. Reset takes all of about 2 minutes.
Old Feb 9, 2010 | 08:43 PM
wreedKR's Avatar
They are not in owners manual, it says to go to authorized dealer.
Old Feb 9, 2010 | 08:55 PM
kingfish51's Avatar
Take a look at the 2008 F150 owners manual. It has the reset procedure in it on page 231. You can look at this manual at www.motorcraftservice.com, in the owners manual section.
Old Feb 9, 2010 | 08:56 PM
wreedKR's Avatar
it says forbidden.
Old Feb 9, 2010 | 08:57 PM
wreedKR's Avatar
working now.
kingfish51's Avatar
it says forbidden.
Takes me right to it. Doing this from work? May be why you can't get there.
You can also try here. https://www.fleet.ford.com/maintenan...ls/default.asp
Old Feb 9, 2010 | 11:35 PM
dilloncawthon's Avatar
this may sound dumb but did you take the neg. off the battery to reset the truck. maybe that will fix it
Old Feb 9, 2010 | 11:40 PM
wreedKR's Avatar
No I have not.
Old Feb 9, 2010 | 11:45 PM
No I have not.
ha it's worth a shot. just take the neg wire off for about 30 minutes then put it back on.
