Minimum Backspacing I can get away with?
Old Nov 25, 2009 | 10:58 AM
svt4lyfe's Avatar
06 XLT 2wd, with 2.5" AS
Going to go with Nitto TG or Cooper LTZ 305/55/20
What is the Maximum offset I can go with? (minimum BS)?
I want to the tires to stick out from the side, and dont mind hacking up plastic on front, , but not to the point where its going to be thumping the fender driving down the road....
please help
Old Nov 25, 2009 | 12:13 PM
LoneRanger93's Avatar
I wouldn't go less than 4.5" backspace.
Old Nov 25, 2009 | 12:47 PM
donbeeler49's Avatar
I agree with the 4.5" of BS. I only have an 8" wide wheel but the wider wheel your use after say 9" you will run into problems, especially those with negative offset. Then you get into trimming and rubbing issues, especially with tires at 12.50 or wider, or those with big side lugs.
Old Nov 25, 2009 | 01:47 PM
-12 with 8" wide wheels, +18 with 9" wide wheels.
Old Nov 25, 2009 | 03:02 PM
svt4lyfe's Avatar
Ok...thanks, idk what the deal is with getting XD wheels these days, wheel pros is backordered like crazy
Old Nov 25, 2009 | 10:12 PM
wandell's Avatar
For the look you want, I'd go with a 9 inch wide wheel with 5 inches of BS.
