Eagle 064 Backspacing
I have KMC HOSS -12 offset 20x9 with 305/55/20 Nitto terra grapplers.I know its not what you are asking for specifically, but its something for you to see.My wheels stick out around 2" I have some more pics in my gallery. usually with a leveling kit i wouldnt go any bigger then a 33. Some guys are fitting 35's which I did with my other truck and i had no rubbing issues. You just have to get the backspacing right and a 10 inch wide wheel is going to be a little tougher. Seek Wandell!! Hes the man.
See there you go...Wandell saves the day!
Heres a few posts with some pics of a 10inch wide wheel. Im sure that the posts are the negative offset you were asking about. Im also pretty sure that Devin4x4 has 305/55/20
https://www.f150online.com/forums/20...-wheels-2.html
https://www.f150online.com/galleries....cfm?gnum=6060
wow...not what I want...what would you suggest...I like the looks of Big Smokeys truck above...Would 20x9 solve it?
You can pull off a 9 inch wheel with that backspacing with minimal trimming...Just a little bit of plastic. F_ast has the same setup as i do only a brand new 150. Also some wheels only come with certain backspacings..If you are dead set on a ten inch wheel it can be done, but its gonig to take more trimming. Id try and find a narrower wheel or and wheel with more offset options. OR LIFT IT!
