35s with just a leveling kit
I'm looking at a new wheel tire combo. I have a 2005 4x4 with a 2-inch leveling kit. The wheels I'm looking at are 17x9 with 4.75 inches of backspacing and a -6 mm offset. The tires are a 35x12.5 (34.9 inches overall diameter). I'm obviously hoping there won't be rubbing here, but realistically I'm guessing there will be some. I'm wondering if anyone has an idea of how much rubbing I can expect. Also, where do tires typically rub? Control arms? The inside of the fenders? Thanks
Depending on the tire brand, toyo/bfg etc. will depend on rubbing. The bfg's in that size from what I hear do not rub at all. But the toyos in that size rub very badly. The side lugs pattern on the toyos is huge. I ended up ordering the 285 75 18 (35x11.50-18) toyo m/ts and never had any rubbing at all. Those measured up like 34.8" and because of the big side lugs looked plenty wide. Pics are in my gallery. Now the bfg's run narrower even for the same size. If you search on here you will find pictures of both and quickly see what I mean.
as for wheels I only have experience with stocks.. hopefully someone will chime in for ya there.
Those wheel's will stick out 2 1/4 inches more than stock and will probably rub on the lower wheelwell's when making hard turn's especially when backing up an incline. I went with 17x8 wheels with 5 1/2 inches of BS to tuck the tire and wheel assy inside the wheelwell's to eliminate the problem. If you don't mind doing some hammering and trimming the wheelwell liner's and put up with a little rubbing you can probably live with it. I ran my tires on 17x9 wheel's with 5 inches of BS about 4k miles untill they aggravated me so bad I changed wheel's. Two other benefit's of wheel's tucked in are that there is less stress on suspension component's and the side's of the truck stay cleaner and less rock chip's.
