what size tires should i get
Old Jul 16, 2009 | 10:01 PM
2wd98f150's Avatar
i want an all terrain tire.
i have 98 f150 2wd with the rough country coil springs (leveling kit) on it and two inch blocks. what size tires should i get?
i've heard 265;75;16 which is a 31.7 10.50
i think i can go a little bigger.
How much bigger?
Old Jul 16, 2009 | 10:04 PM
Dnasty777's Avatar
I had 265/75 on mine before my lift and I'd say those were as big as I would want to go without a level. But since you have a level kit I'd say you can go one size bigger maybe even two.
Old Jul 16, 2009 | 10:28 PM
2wd98f150's Avatar
but how big because i have alot of room.
what about a 33?
Old Jul 16, 2009 | 10:44 PM
wandell's Avatar
You should be able to easily fit 285/75-16's (33x11.50) unless you are using a wheel over 8 inches wide.
Old Jul 16, 2009 | 10:53 PM
2wd98f150's Avatar
i'm using the stock wheel.
are you positive because i'm on the verge of buying tires and i don't want to get the size off and it not fit
Old Jul 16, 2009 | 10:59 PM
wandell's Avatar
Yes. I've seen a few stock 4x2's fit 285/75-16's using the OEM wheels.
Old Jul 16, 2009 | 11:02 PM
2wd98f150's Avatar
they fit those stock?
Old Jul 17, 2009 | 12:01 AM
b2therad's Avatar
Yes 285's will fit. The truck in my signature is a 2wd 98 f150. I have no issues with them at all. The truck isnt lifted/leveled or anything. I think you will like the look of 285's, because I know I did. Looks like a completely different truck.
Hope that helps,
Brad
Old Jul 17, 2009 | 12:21 PM
wandell's Avatar
Yes, you can fit 285/75-16's or 285/70-17 on a stock 97-03 4x2 by using the OEM wheels. However, it's a tight fit and the wheelwells appear too stuffed in my opinion. I wouldn't go that large without at least a leveling kit.
Old Jul 17, 2009 | 03:29 PM
b2therad's Avatar
Wandell is right. It fills up the wheel wells alot but it makes the truck look meaner in my opinion. If you want to know what a 285 mud terrain looks like on a stock height 4x2 just go to my album because you can see really well how much that the 285's fill up the wheel well. I have had the truck like that for a year now and thats with a mud terrain. Your all terrains wont be near as nobby so I doubt you will have any issues either.
Old Jul 21, 2009 | 05:18 PM
2wd98f150's Avatar
where can i find the cheapest tires online. i need to save a buck.
what is an aggressive all terrain that is for a good price
Old Jul 21, 2009 | 05:36 PM
b2therad's Avatar
Ebay has been known to have some pretty good deals. Just make sure the person has good feedback
