Changing 18" to 20" will it affect the braking system?
Old Jun 1, 2009 | 07:50 PM
KR-Texas's Avatar
Originally Posted by wandell
Also, a lot of people install larger tires/wheels and don't correct the speedometer. This means the odometer is off as well. So when they calculate their MPG's it is lower since the truck is traveling more miles than the odometer is showing.
I went from the factory 275/55/20s to 33x12.5x18s and the tire height in person was a lot closer than I originally expected. According to my GPS, my speedometer is only off by about 1 MPH when traveling at 70 MPH, so I did not bother to recalibrate. I have the Xcal2 with my VMP tunes, so I may change it the next time I reprogram.
My mileage dropped from an average of 15-16 MPG to 13-14 MPG, so I estimated a 1.5 MPG drop since adding the 20 lb heavier wheels and tires.
KR-Texas
Old Jul 7, 2009 | 08:38 AM
Big Slick's Avatar
i understand the theory behind the MPG decrease, but Ford's MPG spec on the truck doesn't change regardless of what wheel tire combo your truck has, a la 18" vs. 20".
I just picked up a set of OEM 20's with the stock pirelli's and i'm switching from the 18" FX4's with stock BFG rugged trails. Overall tire diameter is about the same, and I'll try to weigh them before I switch. Should I expect to lose some mileage?
Old Jul 7, 2009 | 09:47 AM
lObOdiablO's Avatar
u r probably right in what u expect
Old Jul 7, 2009 | 05:00 PM
Planning to sell the FX4s? PM me if so.
