Wheel Bearings
Wheel Bearings
2004 F-150 Heritage (97-03) 4X4 4.6L 107,000 miles
Pretty sure I've got a worn wheel bearing. Metal rubbing/whining sound at slower speeds, doesn't change when braking, only on right front. Jacked it up just enough to clear the ground, grabbed top and bottom and it moves quite a bit and clunk clunk.
Question is can these bearings be changed/packed or do I have to buy and replace the entire hub? If so, I believe the best deal I've found is from Rock Auto, any suggestions?
Thanks in advance!
Thanks in advance!
