can i fit 305/45r22 tires on my 2wd??
I have 305/45-22's on my Expy. I've seen a couple of 4x2's with 2/4 drops running 305/40-22's so I think you will be fine with 305/45-22's at stock height. They are only and inch taller than the 305/40-22's.
okay cool, thanks man!
thanks for the info man! i appreciate it!
they're going on the truck this weekend, ill post up some pics!
your also looking at 13in wide. Just bought the same exact tires. Went with the Kelly Fierce's ST. They are 33.2 in height. A nut hair of rubber more than the other. But I need all I can get with the roads in MD. Getting my wheels put on Monday. I also will post pics soon
And where did you go for tires because tireeasy.com is real cheap.
And where did you go for tires because tireeasy.com is real cheap.where in MD are you??
im pretty sure thats a 12 inch wide tire though man.
. Near Andrews AFB. You?
