Tire scalloping or cupping question?
I have a 99 super cab 4x4 and 4 wheel abs. All stock under the engine! My front tires are scalloping (cupping) on the OUTSIDE edge only on both sides(just front)??? Just replaced the wheel bearings(both) and am going to get alignment. I need new tires bad so i wanted to fix this before i ruin the new ones?? any help please chris
thanks alot for the info
I kind of checked my ball joints out when i changed my wheel bearings last weekend but they seemed pretty tight?? i think im gonna look at the ball joints though ( about 60 for whole a arm (moog) )
any other thoughts are appreciated thanks alot chris
Do you have your torsion bars cranked? If so I've heard on some trucks with them cranked up too much it can throw the camber out of adjustment so far an aligment alone will not fix it and a camber kit has to be installed to fix it.
tires
If you lifted the front the outside of you tires would wear without proper alignment just as lowering can wear the inside of tires without proper alignment. A camber kit may be needed if a regular alignment doesn't fix the problem.
thanks alot to everyone who helped. i did crank the torsion bars a little but not a lot. also put on new shocks all around. i got the tires on ( nitto grapplers SWEET) and they alligned it again and it seems fine so i guess well wait and see what happens in a few miles !!! thanks again chris
ITs been about 3000 miles and the allignment guy i took to never said anything about any parts i should replace (ball joints, tie rods, etc, ? ) I now have a little vibration in front at about 65 - 72 ?? Any suggestions or should i try new allignment guy? thanks chris
The guy who did your alignment would have checked your whole front end before he did the alignment. His shop would not waste the opportunity to sell more parts and labor if you needed it.
