Powerslot Rotor changing question
Hey all. I have a front set of Powerslot Cryo Rotors and Hawk LTS pads on order and am wondering if I need to change the front and back all at once?
My rear pads and rotors look fine, but I'd hate to warp the new front Powerslots (due to overworking) if I can help it.
Typically I would just replace the front if I need too, but a slotted rotor is something new to me.
Will my front brakes work harder and cause warping with slotted brakes on the front and OEM style rotors on the back?
All opinions are appreciated...
You liked the braking better with the OEM rears?
With regards to rotors, I run Brembo OEM replacement rotors that are cryogenically treated making them almost as hard as stainless steel. For street use, slotted/drilled rotors are just “cheese-graters” for the brake pads IMHO, because unless you are involved in true racing conditions, the brake linings do not produce the gases which slotted/drilled rotors are designed to relive. In some cases, brake testing indicated reduce brake efficiency in street-based operations using slotted/drilled rotors when equal comparisons were made.
