Question about 35x12.5 on OEM wheels
Old Nov 19, 2008 | 01:35 AM
JKDKALIMAN's Avatar
I have an '02 screw with a 2in leveling kit now, with 285x70x17 on it.
I'm having a Fabtech 6" lift put on very soon and want to get rid of my Mastercraft CT's for the Nokian Vatiiva MT 35x12.5x17.
I was told by someone that there is no way I can put that tire on my OEM wheels without it rubbing even with the 6inch lift unless I buy 8.5 inch wide rims with at least 4.5 inch of backspace.
Someone else told me that it should work.
I would like some of the local resident experts here to please help me answer this once and for all.
Thanks!!
Old Nov 19, 2008 | 12:18 PM
JKDKALIMAN's Avatar
lol 27 views and not one reply? Either noone knows or noone cares....haha...maybe I'll try the Chevy Forum!
C'mon people...I'm one of you! I love my Ford! I love my 150! and I need an answer!
;-P
Old Nov 19, 2008 | 12:25 PM
fx4 for life 79's Avatar
the fabtech lift requires a certain width of wheel and backspacing
Old Nov 19, 2008 | 12:39 PM
heres a couple links to their website
http://www.fabtechmotorsports.com/ap...xpedition.html
http://www.fabtechmotorsports.com/ap...97-03f150.html
Old Nov 19, 2008 | 12:56 PM
wandell's Avatar
The 97-03 oem wheels have 4.5 inches of backspacing just like almost every off road styled aftermarket wheel does. I've seen several 97-03 4x4's with oem wheels and the Fabtech lift. They should work fine untill you can get a wider aftermarket wheel.
Old Nov 19, 2008 | 05:43 PM
JKDKALIMAN's Avatar
Thanks for the replies.
According to one local wheel dealer (after looking my truck up) the OEM wheels have a positive offset of 14mm and that a 17x9 in wheel with a zero offset will work with that particular lift. Fabtech requires a 4.5" minimum backspace which supposedly is the same as a zero offset...dead center..I hope that's right.
It never ceases to amaze me how many answers one can get from posing one what appears to be simple question.
Think I better investagate further!
Thanks again
-Tom
Old Nov 19, 2008 | 10:39 PM
wandell's Avatar
That's the problem with offset, it depends on the width of the wheel. A 10 inch wide wheel with 0mm offset doesn't have the same backspacing as a 7 inch wide wheel with 0mm offset.
Old Nov 20, 2008 | 09:43 AM
minimonster17's Avatar
you will be ok until you can afford wider wheels. fabtech says on their site you can run the stock wheels, which are 7.5'' wide and 4.5'' backspacing. However, they recommend a 9-10'' wide wheel with 4.5-4.625 (4 5/8) in backspacing. Does that make things clear as mud, now?
Old Nov 20, 2008 | 10:43 AM
dave-o's Avatar
backspacing issues aside, if your oem wheel is 7.5 inches and you try to fit a 12.5 inch tire on it, you are going to have crowning issues with your tires.
Old Nov 20, 2008 | 12:11 PM
not necessarily, if you keep the tires properly inflated, and check PSI regularly.
Old Nov 20, 2008 | 05:06 PM
dave-o's Avatar
hell, thats to much work!
