Wheel recommend for 97 Lariat
I have 295/75/16 Nitto Terra's on my truck. LOVE the tires. They are mounted on the OEM 16" rims. 5x135 ,7 inch. I would like to upgrade to new rims and have the tires stick out of the truck about an inch if possible. I tried to use a 16x8 -6mm wheel a MB predator that didn't quite do it. It almost looked almost the same. Didn't widen the stance much at all. What size rim should I be looking for? Any suggestions would be great. Thanks!
Last edited by northwestmichae; Nov 19, 2008 at 12:10 AM. Reason: added more wheel info
something like this?
http://www.offroadunlimited.com/orus...idproduct=8781
Pro Comp Xtreme Alloy, Size 16x10, Bolt Pattern is 5x135mm, Load Rating is 2100 lbs 4.5 backspacing -24mm offset
