305/65/r18 aftermarket rim.
Look on American Racing's website, they list wheel diameter, lug pattern, width and backspacing with offset's. Pretty precise. I'd go with an 8 1/2" wide wheel with 5 to 5 1/2 inches of backspace. These would stick out 1 to 1 1/2 inches more than stock. Also the 305x65 tire is close to 34 inches tall and would look great on a leveled 4x4. Good luck!
Did you have any trouble fitting that size on, did you have to do any trimming, do you have any rubbing etc etc? i'm debating on running the same size (305/65/18) or a 325/60/18 on a Pro comp 7005 with 5" backspacing.
Hey no problem man, i actually ended up getting the same size as you, so i guess i have some trimming to look forward too. The above picture is a little unsettling.
But they look awesome on your truck, so i think it may be worth it (i hope).
