Tire Size ?
Old Jul 27, 2008 | 11:31 PM
FREEMANf150's Avatar
Tire Size ?
Hey yall, im pretty set on buying some procomp mud terrains, 33/12.50/r17 to be exact. Before i get them i want to be sure they will fit with very little or no rubbing. Thanks in advance!
Old Jul 28, 2008 | 12:00 AM
tequilajohnson's Avatar
It depends on what size are your rims and what backspacing they have. If you are using stock rims then you will have no problems. If you wanted you could put 35's on.
Old Jul 28, 2008 | 12:19 AM
Flamed02's Avatar
I agree, check your wheel width and backspacing
Old Jul 28, 2008 | 10:33 AM
Ill be putting them on a 17x9 procomp wheel with 4.75'' of backspacing
Old Jul 28, 2008 | 11:53 AM
4.2trimble's Avatar
you should be ok! But id recommend cranking up your torsion bars to level the truck.
Im not gonna say you wont rub theres too many variables but if you do it will be at full lock and the tire will rub the frame
Old Jul 28, 2008 | 11:56 AM
Yeah im pretty sure ill crank the torsion bars. But with the bs being 4.75'', how much further do you think the tires will stick out?
minimonster17's Avatar
X2, if you have any rubbing, it will be very minor/only on the frame at full lock. you will be okay. the tires will stick out a bit farther, but that is the correct way of dealing w/ wider tires.
Old Jul 28, 2008 | 12:02 PM
Alright thanks guys, i just dont want it to look like some beaner truck
Old Jul 28, 2008 | 12:10 PM
4X4AUTIGER's Avatar
^^ Haha dont worry brandt they wont even stick out as far as mine
Old Jul 28, 2008 | 12:21 PM
Do you think $1380 is a good deal for tires and rims??
