big tires makes for a slug
Old Jul 18, 2008 | 05:42 AM
mark razmandi's Avatar
got 22" boss 335s with tires.....i just measured and i found out my new tires are a whopping 31.25 inches compared to the old 28 inches and they are also super wide.....i like performace and are these tires destroying it becasue i think its slowing my truck down.....my 0-60 after i did my intake and exhaust was the same as when my truck was stock with stock tires...i think thats telling me im right...
Old Jul 18, 2008 | 06:02 AM
MmmBuckles's Avatar
its not the tires thats making you slow. its the 22" wheels. thats where all the extra weight is coming from. go with a smaller or lighter wheel and it should solve your problem
Old Jul 18, 2008 | 06:10 AM
i just bought these and i dont have to ask you to know that changing them now is such a waste of money lmao am i right? and dang look at you being the solution to all my threads lol....thanks :P
Old Jul 18, 2008 | 06:15 AM
MmmBuckles's Avatar
ha. i know how that can be. i guess its time to beef up the performance on the truck now. those heavy wheels are alot harder to move. not to mention stop. dont forget to upgrade those brakes too
Old Jul 18, 2008 | 06:20 AM
sean46's Avatar
A gear change would probably be a big help but not cheap.
Old Jul 18, 2008 | 06:21 AM
MmmBuckles's Avatar
i dont think he needs something that drastic at this point. a nice tune/exhaust/intake should do the trick. gears would probably be the last resort
Old Jul 18, 2008 | 06:24 AM
i gbot intake exhaust and programmer...i was thinkin headers but those are expensive...waht aobut e fans? or u/d pulleys? and a tune up
Old Jul 18, 2008 | 06:27 AM
MmmBuckles's Avatar
tune up can do alot if the truck has never had one. e fans and u/d pulley can also free up some of that restricted HP.
Old Jul 18, 2008 | 06:34 AM
thats what i was thinkin as the best affordabel upgrades
Old Jul 18, 2008 | 09:38 AM
ATOM's Avatar
is your truck 2 wheel drive? or 4x4? a gear swap would be the 1st thing i did if it was mine, why not get back in the rpm range you had before, you didnt lose any power in the sense, just not using it as efficiently. if you lifted a truck 12 inches and put 40's on it, added a supercharger and stuck with the stock gears it still would suck even with 400+ hp. not to mention it would bring back some of your fuel economy.
Old Jul 18, 2008 | 09:42 AM
The big wheels, wide tires cost a lot in performance and fuel mileage. Part of the price paid for the appearance.
Old Jul 18, 2008 | 09:50 AM
05_sprcrw's Avatar
X2
The first thing I would ever do is the gear swap. For something like what your running I would go with probably 4.56's. Are you looking at going bigger in the future? Are you lifted? You have a ton more rolling mass you have to break free now compared to stock, so you drive train has to work harder to compensate for that.
Re-gearing would not only help your truck's mpg, but it would wake it up. You will be amazed at what re-gearing will do for your truck. It will also help to save you from costly repairs later down the road.
Here are a couple links to check out gears:
Gear Swap Write Up Rev. 1
4.10's or 4.56's
MPG with 4.56 gears
This is only a few if you check out this forum tons of info about them:
Other Powertrain forum
Old Jul 18, 2008 | 10:17 AM
4.2trimble's Avatar
If he is a 2wd id recomend 4.30's that would be very nice!
Old Jul 18, 2008 | 10:20 AM
05_sprcrw's Avatar
Good point, I have a 4x4 I am always over looking 4.30s because they do not make a reverse cut.
Old Jul 18, 2008 | 10:49 AM
4.2trimble's Avatar
yeah stupid i think so! but oh well im past needing 4.30's now haha
