285 75 17's?
Old Jun 25, 2008 | 12:23 PM
waterman308's Avatar
285 75 17's?
someone a while back suggested this size for my 03 Ex 4x4 (maybe Wandell?). I've been hunting around to find an AT tire in this size. So far the only thing I found is the Toyo Open Country. Diamter is 33.8" or so.
OEM size is the 265/70/17.
Are there any others that i have overlooked? Most are 285/70s. Nitto has a 295/70, not sure if that will cause rubbing or not. Beyond that I am into the 305/315 and That is just too much (not that I wouldn't like to, but I am in danger of risking my life if I suggest them
As for the Toyo's, would I need a leveling kit, using OEM wheels (another cost savings measure). I'd like to do a 4 corner level, like the Daystar or Truxxx.
Any suggested combinations are appreciated.
Old Jun 25, 2008 | 12:31 PM
f150mudder01's Avatar
Go with 285/75/16's with 16x8" Aftermarket wheels, and crank the torsion bars. You dont need a leveling kit.
Old Jun 25, 2008 | 12:32 PM
south_ms_sprcru's Avatar
im confused why you are wanting that size vs the usual recommended 285/70/17 size that many tire companies offer
Old Jun 25, 2008 | 01:26 PM
wandell's Avatar
I think you mean 285/70-17. I've never seen a 285/75-17. Also, you cannot fit 16 inch wheels on an 03 Expy as was suggested. As for tires, Nitto and BFG also make the 285/70-17's.
Old Jun 25, 2008 | 02:00 PM
You can't fit 16s on an Expy but u can on an F150? damn i didn't know that
Old Jun 25, 2008 | 05:36 PM
yes and yes
Wandell had replied to a previous post for me and indicated that the 03 Ex uses larger disks and the 17" wheel is the minimum. No torsion bars either.
The only 285/75 that I've found is the Toyo open country AT. Nice compromise between rim size and tire height. works out to about 33.8".
Old Jun 25, 2008 | 07:05 PM
Damn no t-bars either???? sorry lol my advice was WAY off!:o i thought the Gen III expys and f150's were the same but i guess not
Old Jun 25, 2008 | 08:12 PM
im thinking that 03 was the model year change for the expy...it happened prior to the f150 i believe...that would explain the need for larger wheels and lack of torsion bars... f-150 was 97-03 (04 heritage) and then 04-08; expy was 97-02, then 03-08...i think
Old Jun 25, 2008 | 08:39 PM
wandell's Avatar
Yep, you are right. The Expy changed body style in 2003 while the F-150 changed in 2004.
Old Jun 25, 2008 | 09:17 PM
..that explains it! preciate it!
Old Jun 26, 2008 | 01:25 AM
wasachevyguy's Avatar
i like the sound of that 285/75R17 from toyo. the exact same dimensions as a 305/70R17 but a little narrower. maybe reducing the weight a bit is a good thing, expecially with only 3:55s. they must be rare because ebay has no listing at all in that size. the search will continue.......................
