Tire / Wheel size question
Old Jun 19, 2008 | 10:43 AM
wandell's Avatar
I didn't realize you had a 4x2. They sit about 2 inches lower than 4x4's. That combo will not fit. A 325/65-18 is essentially a 35x13.00 tire. You may be able to fit a narrow 33 inch tire, like a 285/65-18 with those wheels, but it will be tight. I'd go with the ones with 5.7 inches of bs.
Old Jun 19, 2008 | 02:22 PM
Blue150's Avatar
I originally wanted out of my factory wheel because I thought a 295/70/17 would look stupid but I actually just saw a set in person. I was on a smoke break and saw a 4WD dodge 2500 HD with big old Toyo M/T's. I have been oogling this trucks tires for a few weeks now. Today I actually got close enough to read the size. 295/70/17. I did not realize they were this big. I got a wild hair today to pull my rims off my truck, blast them, do a custom powder coat job on them myself and get me 295/70/17 TG's. If I can find a place to set my truck up on jackstands for a week I will start this soon.
Old Jun 19, 2008 | 02:46 PM
Val3ntin0's Avatar
Same here, about to pull the plug and let the truck rest on some stands in the driveway while my rims are being powder coated.
Wandell, if I remember correctly, you said that with a 20" rim you can typically put in a 305/55/R20 on a 4x2. What would be the largest I can fit with a 18" rim diameter (with and without a 2" level)? Also, if different from your answer to my previous question, what would you recommend size-wise with and without a 2" level? I know you're the wheel expert so what you say I take as the "law".
Old Jun 19, 2008 | 03:48 PM
Blue150's Avatar
This is the look I want! This is MacsFX4, he just posted these in another place but this is look I want with my new wheels. Is this not possible on a 4x2 with only a 2.5 AS?
http://img371.imageshack.us/my.php?i...ture004mu9.jpg
Old Jun 19, 2008 | 10:29 PM
wandell's Avatar
With a leveling kit on a 4x2, you should be able to fit up to a 33x12.50 (305/55-20, 305/65-17, etc) with the right wheel. I'd suggest a wheel no wider than 9 inches with at least 5 inches of backspacing.
Old Jun 20, 2008 | 09:40 AM
Blue150's Avatar
You da man! Thanks! I will be back here once I find a set I like.
Old Jun 20, 2008 | 03:05 PM
Blue150's Avatar
Would these work?
http://cgi.ebay.com/ebaymotors/ws/eB...m=150260139935
Would you still recommend a 295/70/17 on them?
Old Jun 20, 2008 | 11:06 PM
wandell's Avatar
See if you can find out what the backspacing is. I'm not good with offsets.
Old Jun 20, 2008 | 11:14 PM
Blue150's Avatar
Found it.
17x9 Black 6 on 135mm -8mmOS 4.625BS 2100lbs. 27 lbs.
Old Jun 20, 2008 | 11:15 PM
wandell's Avatar
That wheel is gonna stick out about 2.5 inches farther than your OEM wheels. I think you are gonna have some serious rubbing with those and 295's.
Old Jun 20, 2008 | 11:30 PM
Blue150's Avatar
ok, I will look for a 17x8 with 5 inches of BS. will that work better with the 295? I think Mod Bargains has a set I liked that were like that.
Old Jun 21, 2008 | 12:28 PM
wandell's Avatar
Yeah, an 8 inch wide wheel with 5 to 6 inches of bs would be much better.
Old Jun 21, 2008 | 04:20 PM
Blue150's Avatar
I have finally made a decison. I know, I am as bad as Fich Chris with my indecisiveness. LOL Sorry Chris..
Anyway, I just agreed to buy a fellow members 18" FX4 wheels. I have a place that is going to blast them clean for me so I can powder coat them satin black. Too good a deal to pass up. Now, what size tire can I put on them? I want the biggest I can go without rubbing. I am still debating betweent he TG's and the Toyo Open Country M/T's. New wheels are 18x7.5 like these, as a matter of fact, this is one of them:
Old Jun 22, 2008 | 10:31 AM
wandell's Avatar
Those are nice. You may be able to squeeze some 305/65-18 (34x12.50) BFG AT KO's on there. You should be able to fit 33x12.50-18's without any rubbing.
Old Jun 22, 2008 | 01:00 PM
Blue150's Avatar
Cool. thanks.
