Nitto or Toyo..or any other suggestions?
Im getting a new truck either in July or a couple months later and i need suggestions on tires. I'm looking for a 37x13.50 tire rim size either 18" or 20" and I might even step up to a 38x15.50 tire depending on how much money I'll have. Now i'm stuck between the Nitto Mud Grapplers and Toyo Open Country MTs. What do you guys reccomend?
Personally, I prefer the Toyos, they look better imo. I would go for 37/13.5r20, it would be a nice wheel to rubber ratio. I'm running Toyo MT 35/12.5r20 and they look pretty sweet with my 6" lift, so I'm sure the 37's would look cool just as well on a 8"+ lift.
On a side note, the Toyos will more than likely ride/sound better on the pavement, city and highway. Plus, from speculation and previous posts, most people get a lot better tread life on the Toyos compared to the Nittos. As far as functionality... The Toyos will serve you more than well enough in the mud. You more than likely would never get stuck unless you ran into a lake.
+1...Nitto has Toyo beat in the A/T department, but Toyo has Nitto in the M/T department. I saw both over the weekend, infact I saw the Nitto Mud's in size 37...it honestly looked like a construction vehicle. The tires looked like they came off of a backhoe. Toyo for M/T...Nitto for A/T. Or...even the new BFG KM2...saw them too in size 37.....badass is the only word that comes to my mind.
I would personally recommend the Cooper Discoverer STT's. I have had them on my truck for almost 8k and they are a great tire. Not really loud on the roads, great wearing, and great looks. Not to mention, they are a little less expensive than the Toyos with pretty much the same tread and a more aggressive sidewall. They are at least worth checking out.
However, if you can only pick between the Toyo's and Nitto's, then go with the Toyo's.
