Calipers loose?
Old Apr 15, 2008 | 11:20 PM
munoxide's Avatar
Calipers loose?
Today i just noticed that, going over rough, bumpy streets that my calipers are bouncing around making a clacking noise and it stops when i push the brake pedal. I puled the front tire off the passenger side and the bolts are both tight, but its moving in a front to back motion which is whats making the noise but what im wondering is if the floating is supposed to be there, then whats causing the loud clatter noise in them when going over bumps? For the longest time i thought the noise was coming from the wheel hubs but its defiantly from both front calipers. '01 scab 5.4......Thanks
Old Apr 16, 2008 | 06:31 AM
torkum's Avatar
If you have a 4x4 its probably a bad hub bearing.
Old Apr 16, 2008 | 10:47 AM
munoxide's Avatar
Oh i forgot to put, its a 4x2.
Old Apr 16, 2008 | 12:23 PM
mkosu04's Avatar
when you say that they are moving "front to back" do you mean relative to the vehicle or relative to the caliper?
Old Apr 16, 2008 | 12:47 PM
faulkincanyon's Avatar
Be carefull my truck did this and ended up rubbing a groove on the inside of my wheel causing it to split in half while I was driving...ended up being a bolt that backed out though so if your bolts are there I dont see why they would be moving
Old Apr 16, 2008 | 01:11 PM
boss1984's Avatar
i have the same problem with my rear brakes though!! i cant seem to figure out why they move side to side..the bolts were taken out cleaned and have loc-tite but they still have some play in them
Old Apr 16, 2008 | 02:57 PM
Evil Homer's Avatar
Are the anti rattle clips still in place or did they fall out somewhere?
That was the culprit on my old truck. Put new clips in and the noise went away.
Old Apr 16, 2008 | 03:54 PM
keenanhons's Avatar
this happened to me the other day. the top bolt that holds the caliper on backed out and the caliper fell down and rubbed the wheel. luckily i caught it in time and it just scratched it. but for awhile is was sounding like you were explaining.
Old Apr 16, 2008 | 11:24 PM
munoxide's Avatar
They are moving front to back as in from the front bumper to the rear bumper.
Old Apr 16, 2008 | 11:25 PM
munoxide's Avatar
Where are the anti rattle clips located? do you have to remove the caliper to get to them? I dont know if they fell out, but most likely thats whats wrong. Thanks
Old Apr 17, 2008 | 10:37 AM
Evil Homer's Avatar
They should be right next to the caliper both above and below, I can't seem to find a decent picture however.
However, look at the picture here.
http://www.charliebravogroup.com/bjoints/25.jpg
and right where the caliper sits between the two pieces of black metal there should be little spring clips, one on the top and one on the bottom. This stops the caliper from rattling between those two metal parts.
Old Apr 17, 2008 | 11:00 AM
munoxide's Avatar
Ok, thanks alot. Ill pull the wheel off and take a look at it.
