Toyo MT's pulling HARD right???
I got my tires aligned and even got a front camber/caster kit installed. The alignment is dead on but the truck pulls to the right hard. I took it back and they said that sometimes the tires can pull one way or the other. Does anyone else have this problem? I've got 35 12.50 on 18in oem with a 2.5in leveling kit.
Are you sure its no just the road slanted toward the shoulder and it seems like it is pulling?Bigger tires will pull harder because they have more leverage then your little stockers.Some allignment places will actually put it off a little toward the left so your steering wheel will be straight when going down these roads so it doesn't seem like its pulling but with it dead on center then yeh,its gonna seem to pull to the right because the road isn't flat,its slanted to the right,unless your in Europe ,then it will be to the left
