Gears for 35" tires
Gears for 35" tires
Hey I'm new at this whole lifting thing and I have a few questions. I've read a lot of threads and it seems everyone has a different opinion and all the forums get off of the topic and it's annoying lol. I just bought a 08 f150 5.4L flex Fual with the 3.73 limited slip 4X4. I've ordered a fabtech 6" lift with and add-a-leaf kit for the rear, and 20" ECO wheels with 35" nitto terra grappler tires. I am pretty sure I need to go with different gears for the axles but I'm not sure.. can I run the stock 3.73's or will I just kill my power and fual mileage? Should i go with 4.10's and be batter off with being able to tow and everything, I also plan on Gibson extreme duals and volant CAI in the future as well as the Jet plug-in module. any suggestions?
Just curious... wouldn't gas mileage improve on the highway due to gear ratio causing the engine to turn less rpms? It'd be a trade off... worse gas mileage to get moving, but better gas mileage once moving.
As far as weight, you're trading 5 wheels/tires for 4 so weight wise you may be alright... but of course, you have more rotational weight which obviously makes more of a difference than total weight when it comes to power/gas mileage.
Gearing is a compromise. If the truck is geared too tall, the engine will be in a strain and lug, causing poor gas milage. If the truck is geared too low, the engine will turn too many rpm causing poor milage. The factory tries to find the ideal compromise and usually go on the tall side with gearing. Therefore, mpg's usually go down when you install a taller tire.
Stock = 265/70/17 = 31.6x10.4/17
To:
315/70/17 = 34.4x12.4/17
A different of 2.8 inches... how much of a difference do you think it would make weight wise, and ratio wise?
ok so hlp me with this one. "99" 150, with the 4.6, i have a rather large lift (11inch front,12 back) and i'm gonna stick 37s under her soon, i still have stock gears, but i still travel a bit to and from work(highway) , but i also tow stuff all the time in the summer, (4wheelers,pop up camper, scrap metal, no more then 4-5000pounds) what should i change to? 4.56,or 4.88, 4.11(do they have 4.11?)
thanks Junior
thanks Junior
