Probably a stuid Question about33 inch tires
new the pick up truck world i have an 2006 xlt supercrew i want to put 33 nitto tires in with a leveling kit which the truck place by me says they can fit but my question is what happens if i get a flat with the bigger tires on can i even put the spare on with the bigger tries?? thanks for the help guys
Or if you do get a flat in the rear and you have LS, you can take a 33 off of the front and put it on the rear, then put your OEM spare on the front. I wouldn't drive on it for a while but if you go straight to a replacement, you should be OK.
That's the plan with my 35's if I get a flat on the rear.
And apparently new to the grammar world also.
Why don't you just buy 5 tires? Then you'll have a full size spare.
