07 Screw Fx4... will 35's fit?
I am wanting to beef up my truck a bit and was thinking about getting a Leveling Kit and want to keep the stock 20's on it. Will I be able to get 35's to fit w/o rubbing? Or will I have to go with 33's instead? Any help is appreciated and PLZ post any pictures of an 07 screw with 35's and leveling kit... Thanks
yea there gonna rubb
mine are 35x13.00x20 (325-60-20) km2 i had to run a 1/4" spacer on my front to get them to clear the upper ball joint but some other members were able to run the same size in the bfg a/t without the spacer
I would suggest going with a 285-65-20 with a leveling kit and you will not rubb even at full lock also if you consider going with a 33 (305-55-20)
there are also going to rubb at full lock
Love your truck... how is the tire life of those KM2's? I had some AT's on my jeep and they wore out a bit fast on it... might just be my driving style... do you need to add an Add-a-Leaf for the rear to clear those 35's? again, your truck is awesome... exactly the beefiness i am goin for
i have about 7500 miles on the tires and they look really good still
But with that said i would advise going a little smaller than the 325-60-20
they are just a little to wide unless running a spacer on the front does not bother you
