Confused
Old Jan 29, 2008 | 10:37 PM
Meffects01's Avatar
Confused
Hey guys i got a problem here.... I want to get a new set a wheels for my 2001 Supercrew... problem is i can't lower it because i use the truck to go to the ranch from time to time and well the streets where i live suck. I can't put a lift on it because my parents still have to be able to get in... and they have a hard enough time as it is...
My question is what would be a good looking set of wheels that aren't too expensive that will "work" with my truck? Or should i just give up and stay with my stock?
Old Jan 29, 2008 | 11:17 PM
4.2trimble's Avatar
well really any wheel will look good but its more of a preferrence! go to wheelsforless.com they have a good selection! id say go for a 16-18" wheel with the same size tire you already have, thus you are not increasing or decreasin ride hieght!
Old Jan 30, 2008 | 12:04 AM
MOford21's Avatar
If your parents have a hard time getting in, you might put steps on it if you haven't already..
Just a thought.
Old Jan 30, 2008 | 12:08 AM
Meffects01's Avatar
haha got steps.... they are just old and have arthritis
Old Jan 30, 2008 | 12:11 AM
MOford21's Avatar
I see...
Well wheels/tires shouldnt raise it at all if you get the same size or equivalent tires..
And even if you go slightly bigger, I don't think it would be noticeable.
Old Jan 30, 2008 | 12:23 AM
Meffects01's Avatar
Well I'm not necessarily worried about the wheels/tires raising/lowering me. It's just usually in order to make the wheels fit with the truck... the truck is usually on a lift or lowered. I really haven't seen a truck at stock level with after market wheels that fit with it, or I'm just blind and haven't noticed.
Old Jan 30, 2008 | 12:49 AM
MOford21's Avatar
You can put all sorts of wheels on a stock truck.
Many people on this forum just get the "mod bug" and start lifting, etc.
You can put 16-18 inch wheels on no problem.
Maybe even 20s, but I'm not sure, I'll let someone else chime in on that.
Old Jan 30, 2008 | 12:17 PM
wandell's Avatar
Do you have a 4x4 or 4x2? Do you want an off road or street truck look?
Old Jan 30, 2008 | 05:45 PM
Meffects01's Avatar
i have a 4x2. I guess I'm looking for more of a street scene. I think once i get new wheels i will just swap out my old ones when i go to the ranch. I just want something nicer then stock wheels. :o
Old Jan 30, 2008 | 10:25 PM
wandell's Avatar
I'd install a set of 2 inch drop shackles out back and some 305/40-22's.
