325/50/22
Old Nov 12, 2007 | 01:57 AM
guitarman502's Avatar
325/50/22
just wondering if you all think i could fit a 325/50/R22 on a 04 (new body style) screw 4x4 lariat with a 2 inch leveling kit?
Old Nov 12, 2007 | 01:59 AM
t-rev's Avatar
eh, mite b some minor cutting.
Old Nov 12, 2007 | 02:05 AM
ah yeah... forgot to mention i have the stock harley 22's... if that matters in fitting them
Old Nov 12, 2007 | 12:12 PM
wandell's Avatar
That works out to be a 35x13.00-22 tire. It will be extremely tight. Several members here have fit 35x12.50's on 04-08 4x4's by using the oem 17, 18 and 20 inch wheels and a leveling kit. Most report minor rubbing on the control arms at full steering lock.
Old Nov 12, 2007 | 12:56 PM
how do you think it would look? I mean the only thing i dont want is the front end sitting higher than the rear.
Old Nov 12, 2007 | 08:00 PM
wandell's Avatar
Personally, I'd want a wheel smaller than 22 inches with a 35 inch tall off road tire.
Old Nov 12, 2007 | 09:46 PM
built54's Avatar
same here, 33x20
Old Nov 12, 2007 | 10:50 PM
wasachevyguy's Avatar
my local tire dealer rides on 325/50R22 nitto terra grapplers on aftermarket rims on his shop truck. he only has a leveling kit. it looks absolutely awesome! i actually asked him how much he wanted for the set and he said $4500. i told him i'd keep looking.
Old Nov 12, 2007 | 11:15 PM
the nitto's i'm looking at are right at 1400 a set....think you could snap a picture of the truck sometime?
Old Nov 15, 2007 | 04:01 PM
KR-Texas's Avatar
I think the larger wheels and smaller sidewall tires do not look good on a 4x4. I prefer 18s on any tire smaller than 37" and 20s on everything else. There is a guy on here who has 24s with 38s (or maybe 40s) and the tires do not have enough sidewall height for my taste. Almost looks like a big roller skate.
If you want a little more room for the 35s, you can always go with the 2.5" on the front and a 1" shim or block kit on the back. To prevent the rear from sagging when you tow, add a leaf on top like the ones from SuperSprings.
http://www.supersprings.com/
KR-Texas
Old Jul 20, 2015 | 11:30 PM
Boosted512's Avatar
here in my 14, with 325/50/R22 toyo at2s, with 2 1/2 inch level kit with block in the rear wheels have a -24 off set and they do rub. <br/>
