Auto Zone or Checker rotors?
Rotors are rotors to me, typically they offer at least 2 choices, thicker is usually the more expensive so i like them for added assurance. Pads are where to pay attention because they offer more brands. There you should get a good semi-metallic with a warranty against excessive wear but mostly dust and noise.
Originally Posted by Shinesintx
Really? Is that a Yankee thing? You dont turn your rotors? They dont squeek and squeel like Erkel on helium?
no, what i meant was the rotors themselves are machined and given a new surface. but now that you mention it, it has to be a yankee thing. when i lived in fayetteville, NC even autozone had a rotor machine and would turn them for 6$ a rotor.
I have gotten mine turned or cut a few times before they got replaced, the original rotors that is. Once I'm due for front pads again, I'll likely turn these rather than replace them. The rears are gonna be replaced pretty soon as they are originals and are looking pretty old.
Alot of times, if what you have is good enough for just turning or resurfacing, do it. Sometimes the cheapest rotor is just that because when the pads go, the rotor is either warped or too thin to cut. Just weigh your options, often replacing with new rotors is too cheap not to.
Originally Posted by sevenseven
Ok thanks for the insight. I looked at the R1's online. Are the replacement OEM's any good or do you run the slotted ones?
